remove headlamp rubber boot cover from bulb section at back of lamp assembly,now turn ballist clockwise to remove unplug wiring from ballist 1st ,than bulb has a wire type lock pull & remove bulb but pay attention to how bulb is set in housing ,also pay attention to how ballist was taken off ,the ballist also has a lock if that shifts u will not be able to refit correctly ,if after u replace bulb & light still inop u will need to replace the control unit mounted under the bottom side of said lamp assembly ,good luck.remember to refit wiring to ballist .
Jan 13, 2010 at 8:06 AM
