2001 Saab 9-3 repair Question no directionals on passenger s
2001 SAAB 9-3
94,000 MILES • 4 CYL • FWD • AUTOMATIC
MANGOJOE
Right blinker not working, dashboard light is rapid flash, display reads rear light failure...I have replaced my bulbs, replaced my hazard switch with no luck.Any help would be greatly appreciated...Heidi
Sep 7, 2010 at 9:38 AM
2 LINSEY
  • 287 POSTS
Hi mangojoe,, Check for blown fuses and look where the bulb makes contact with the socket and make sure there is no corrosion. if there are any grounds that you can see for the rear light plugs check to make sure they are good. Also look for broken wires going to the rear light sockete let me know what you find. Good Luck!
Sep 7, 2010 at 4:06 PM
