I have a gm diesel engined saab 93.
Keeps on losing coolant - litres of it
when the car is run on the driveway it all seems ok but when driven the coolant low light comes on the expansion tank is empty,
the thermostat has been tested and is ok.
the heating in the car is freezing even when set hot and
the engine temp gauge says all is fine
cannot find an obvious leak and no mixing of fluids in the engine so hopefully not head gasket
and no obvious leaks around the water pump
Aug 13, 2008 at 3:33 PM
