2001 Saab 9-3 repair Question coolant loss
2001 SAAB 9-3
140,000 MILES • 4 CYL • FWD • MANUAL
STATHAMS PIES
I have a gm diesel engined saab 93.
Keeps on losing coolant - litres of it
when the car is run on the driveway it all seems ok but when driven the coolant low light comes on the expansion tank is empty,
the thermostat has been tested and is ok.
the heating in the car is freezing even when set hot and
the engine temp gauge says all is fine
cannot find an obvious leak and no mixing of fluids in the engine so hopefully not head gasket
and no obvious leaks around the water pump
Aug 13, 2008 at 3:33 PM
MERLIN2021
  • 17,250 POSTS
Any smoke comming from the exhaust? If you see smoke, could be a head gasket problem. Get a block test done and it will tell you if the head gasket is leaking. A pressure test will find small hard to locate leaks.
Aug 13, 2008 at 4:47 PM
STATHAMS PIES
no smoke
the engine seems to be running fine
and the amount of coolant its losing is vast
but the temp gauge says normal
could it be an airlock?
Aug 13, 2008 at 4:57 PM
MERLIN2021
  • 17,250 POSTS
yOU SAY THE AMOUNT OF ANTIFREEZE LOSS IS VAST, CAN YOU SEE A LEAK? Sorry about the caps, laptop has caps lock in bad place!
Aug 14, 2008 at 3:51 PM
