2001 Saab 9-3 ANTENNA WILL NOT GO DOWN ALL THE WAY
2001 SAAB 9-3
99,500 MILES • 4 CYL • 2WD • AUTOMATIC
TULSA
What is the cost to have it looked at and then to maike it work/repair?
It sticks up about four inches
Thanks
Oct 15, 2010 at 12:21 PM
MNTHNY4
  • 612 POSTS
did u try cleaning the antenna mast ,turn radio on ,now with antenna all the way up ,simply use some clean solve & wipe mast off & check for damage to mast ,after cleaning check if working ok now ,if antenna still dont go all the way down u may need to replace just the mast [or the antenna rod] only .good luck.
Oct 18, 2010 at 8:41 AM
