Car will not restart after driving, Checked and has no spark, will start after sitting for a couple of hours.
Jul 22, 2010 at 11:05 AM
FACTORYJACK
CERTIFIED EXPERT
Possible that the crank sensor is failing thermally. Check the resistance of it when warm, it should be around 950 to 1250 ohms. Sometimes when hot the resistance rises out of limits, and it can even go open. It is a three wire sensor, I believe it is pins 1 and 3 that you check.
