2000 Saab 9-3 repair Question My 00 Saab 9-3 Has oil leak fr
2000 SAAB 9-3
59,600 MILES • 4 CYL • 2WD • AUTOMATIC
RCDUDE22
My 2000 Saab 9-3 Turbo (4cyl) has a small oil leak from the bottom side of one of the screws that holds the top portion of the motor, valve covers, to the bottom.. is not engough to drip.. more of a sludge.. but none of the other bolts has this from the bottom. A better idea is if you were standing in the front of the car looking at the motor, the screw is the fartest one right. Motor has oil, no weird smells or anything out of the norm. I think its a washer that could not be making a seal correctly, what do you guys think?
Adam
Dec 20, 2007 at 12:55 PM
IRISHMOBILEMECHANIC
  • 10 POSTS
hello you rocker gasket(as its more commonly known) needs to be replaced have it done asap rather than wait for it to get worse it is an easy diy fix
regards irishmobilemechanic
May 1, 2008 at 5:44 PM
