1999 Saab 9-3 repair Question tps
1999 SAAB 9-3
127,000 MILES • 4 CYL • FWD • MANUAL
BMARCUS26
where is the tps (throttle position sensor) located?
Jun 24, 2009 at 7:03 PM
BLUELIGHTNIN6
  • 16,542 POSTS
TPS is located on the throttle body itself.
Jun 24, 2009 at 7:07 PM
BMARCUS26
thank you!
Is this something that can be changed if the part is purchased at a prts store?
It has two bolts? Can I just switch it out? is it easy for a weekend mechanic?
Thanks
Jun 25, 2009 at 7:49 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Yep, this is a fairly simple repair. Disconnect the negative battery cable. Then unbolt and disconnect the old TPS and replace it with the new one. Reconnect negative battery cable. Should fix you right up.
Jun 25, 2009 at 10:38 AM
BMARCUS26
Hi, thanks for your help on the TSP!
Worked just as you said! Your AWESOME!
I need to replace the oil pressure switch now.
Is this something easy to do? I am not sure where it would be on the engine of my Saab 9-3 turbo. 1999
Thanks!
Jul 10, 2009 at 9:50 AM
BLUELIGHTNIN6
  • 16,542 POSTS
Your vehicle has an oil pressure sensor, not a switch. It is located under the intake manifold. May need to remove a few components to gain access to it. Should remove it same as the TPS, just disconnect it's electrical connection and unbolt it from its location.
Jul 10, 2009 at 12:31 PM
