1999 Saab 9-3 repair Question Thermostat Removal
1999 SAAB 9-3
20,700 MILES • 4 CYL • FWD • AUTOMATIC
SWIFT55
Hello. I just need to make sure that the thermostat is in the housing that the top radiator hose connects to? And if so, exactly what bolts do i need to take loose up top. I'm not concerned about flushing the coolant. Thank You. And if you have a diagram that would be very helpful.
Feb 14, 2010 at 4:16 PM
MNTHNY4
  • 612 POSTS
u need a 13mm socket & short extension plus a 10mm wrench to remove bolt from water tube coming from water pump ,there is no other thing to pull housing only has two 13mm bolts holding it in place ,make sure to refit thermostat just like how u take it out ,with pressure valve at top ,good luck.
Feb 15, 2010 at 7:33 AM
