1999 Saab 9-3 repair Question clutch
1999 SAAB 9-3
162,000 MILES • 4 CYL • 2WD • MANUAL
1999SAAB
is it hard to replace a clutch in a 1999 saab 9-3
Jan 29, 2008 at 7:31 PM
IRISHMOBILEMECHANIC
  • 10 POSTS
hello, its no harder than most cars,it depends on your degree of mechanical experience,involves removal of front struts ,gearbox etc,if you have little experience i would not recommend you attempt yourself due to the critical systems involved(braking system,electronics etc,)for obvious reasons if you are unfamiliar with brakes and the like best to stay away as a failure in the braking system is nearly always catastrophic
regards irishmobilemechanic
May 1, 2008 at 5:28 PM
