1999 Saab 9-3 repair Question ABS/BRAKE Light
1999 SAAB 9-3
MIZZABOONE
Brakes problem
1999 Saab 9-3 repair Question 4 cyl Front Wheel Drive Manual 146k miles
The ABS and BRAKE light on my dash turns on intermittently. What could be the cause of that? They seem to turn on when the car goes over a speed bump or if I'm tuning and going up hill. Can someone help me?
Oct 22, 2009 at 7:53 PM
MNTHNY4
  • 612 POSTS
check your brake fluid level ,if found ok then u may have a abs unit going bad ohoooc if found bad not cheap to replace if going with new unit ,get your codes read & post back ,if any .
Oct 23, 2009 at 9:57 AM
SUISHEN19837
[quote:bd14405772="mizzaboone"]Brakes problem
The ABS and BRAKE light on my dash turns on intermittently. What could be the cause of that? They seem to turn on when the car goes over a speed bump or if I'm tuning and going up hill. Can someone help me?[/quote:bd14405772]
Hey, I also have that problem when I turn left. The hand brake light is on at that time. But my ABS light is not on. Is that caused by low brake fluid level? Thank you Sir.
Nov 8, 2009 at 1:04 AM
MNTHNY4
  • 612 POSTS
yes check your brake fluid level,further more check your brake pads for wear
Nov 8, 2009 at 8:46 PM
