Rusted crankshaft sensor
2005 JEEP LIBERTY
163,000 MILES • 3.7L • 6 CYL • 4WD • AUTOMATIC
CASMIHOK
  • 205 POSTS
On my long list of repairs needed before I can go home, I am starting with this crankshaft sensor since I have it already.
Bolt came out easily, unclamped easily from the wiring connector as well. But, its oddly rusted on the limb that is held by the bolt.
I have PB Blaster and WD40, but I don't want to spray there if it's going to mess with electrical components.
What can I do?
Thank you guys.
Have a blessed day.
Dec 9, 2019 at 1:45 PM
CASMIHOK
  • 205 POSTS
For some reason when I click on this link off my list of questions, it says page 404 not found error. But if I click the link off my email, it brings me here. Not sure this went through, hopefully it did.
Dec 9, 2019 at 1:49 PM
SCGRANTURISMO
  • 4,897 POSTS
If you are going to replace the Crankshaft Position Sensor [CKP], then I wouldn't worry about hurting the old one. Keep the electrical connector away from the PB Blaster and douse where it is rusted at.The main thing that you want to preserve are the threads in the bolt hole. The CKP, once free from the rust, should just pull out, it's the bolt, obviously, that secures it in place. Please get back to us with how everything turns out.
Thanks,
Alex
2CarPros
Dec 9, 2019 at 3:08 PM
CASMIHOK
  • 205 POSTS
Okay, will do. thank you.
Dec 9, 2019 at 9:15 PM
STEVE W.
  • 15,113 POSTS
Did you have any luck getting it out? The way that is rusted makes it look familiar. What is the reason for replacing it? Engine refuses to run?
Dec 12, 2019 at 10:13 PM
CASMIHOK
  • 205 POSTS
I have been working on it for about a week with PB Blaster and a set of pliers. I got it twisting and rocking slightly, but the black plastic is still really stuck in there. Any tips or tricks? I need to get this thing out. And yes, my car is currently broken down and this is a code I am getting. I just want to go back home.
Thank you
Dec 20, 2019 at 4:49 PM
STEVE W.
  • 15,113 POSTS
The o-rings can get really stuck in there. I've used a few things to get them out over the years. What is the code you are getting? I have seen a bad cam position sensor trigger a false crankshaft code before on them. How did you test the sensor?
As for getting them out, I've used heat on the block to bake the o-ring and melt the outer case of the sensor enough it comes free. I've also sprayed lithium grease in there and pried on the parts outside the block. I've even got ticked off and smashed the outer part off so I could get into the hole and clean the rust out. To do that requires that you drill a hole into the sensor and put a long screw into it, then cut or smash the outer part off and go after the rust. I've also known of folks who just snapped them off, then dug them out with a die grinder.
Where are you stuck?
Dec 20, 2019 at 8:48 PM
CASMIHOK
  • 205 POSTS
I'm getting a p0339. I got it initially about a month back, and then it went away after I replaced spark plugs and a melted ignition coil. But, it then came back when my truck broke down about a week and a half ago. You can see my previous questions to see exactly how I broke down, what happened and such. I drained the oil because my oil light came on. My oil looks perfect. My father said that a bad crankshaft sensor could cause all of it, and he said that the crankshaft sensor could be the reason I also now am getting p0344.
I only got the camshaft p0344 the second time I got the p0339. So this camshaft sensor code is recent, my father recommended replacing my crankshaft, clearing the codes, and seeing if the camshaft comes back. But, I am stuck with the crankshaft sensor in there. I have it twisting freely, counter clockwise and clockwise, and I have very very slight movement back and forth. But no significant movement outwards
Can you confirm anything he said? Thank you
Happy holidays Steve!
Dec 20, 2019 at 10:26 PM
STEVE W.
  • 15,113 POSTS
Sounds like he knows his stuff pretty well. Your codes are both intermittent circuit codes. That means it could be the sensor or it could be the wiring. Do you have access to a multi-meter? If yes you can test the wiring between the crank sensor and the PCM. Also follow the wires themselves, look for any damage or corrosion as those two share the same sensor ground. Would also test the sensor as it seems to have failed now and should show as bad. For that you need the multi-meter again. Or as an emergency test, take a jumper wire, and find the dark blue wire with a dark green trace on it in the wires to the crank sensor. Bare a small spot of the wire and connect the jumper wire from that to battery negative. Stick the bolt back in the crank sensor and see if it fires now. If it does the sensor ground wire is the problem.
Dec 20, 2019 at 11:18 PM
CASMIHOK
  • 205 POSTS
I'm fairly clueless and just learning as I go, so I apologize
My buddy let me borrow his multi-meter, I have no idea how to use it but I'm sure a quick YouTube tutorial could show me. Correct me if I'm wrong but I think you're under the impression that my car is not starting at all? Which makes sense because I mentioned I had broke down, but I should add that I broke down and then was able to start up again to just make it home a few miles. I haven't tried to start the car since then, but I think it would start if I tried.
Does the car have to be running to use a multi-meter?
Thank you.
Cas
Dec 21, 2019 at 11:52 AM
STEVE W.
  • 15,113 POSTS
If the engine will start it likely isn't the crank sensor that's bad. Those usually just fail and done on those engines. However being the codes are both intermittent circuit codes and that Jeep being rusty a bad ground or corroded splice are both very likely. Finding it will be the difficult thing. The first place I would look is the ground wire they both share. If the meter you have has a continuity beeper it could make it easier. The visual inspection I mentioned would be the first thing though. Don't be afraid to open the wiring loom and trace the wires. There are numerous line splices that could corrode or the wires may pass over a spot where the loom rubbed through.
The meter can be used with the engine off for some tests and the key on for others.
There are a lot of guides for meter use out there, they may not match exactly to the meter you have but ohms are ohms, volts are volts.
Dec 21, 2019 at 4:39 PM
CASMIHOK
  • 205 POSTS
Well, given that I have doused the sensor that's in my truck with PB Blaster, I guess I have to get it out and replace anyway. I am completely clueless when it comes to electrical, I don't even know where to begin. Wish me luck! I will let you know how it goes.
Dec 21, 2019 at 8:01 PM
CASMIHOK
  • 205 POSTS
So I tested the wiring that goes into my crankshaft sensor and got a voltage of 3.5. Does that mean my wiring is okay?
I also have not made progress on the crankshaft sensor. I think I just want to drill it out, is that a safe process? Is there anything that could go severely wrong? I feel like with the way the sensor is pointing semi downwards, it's unlikely that I could lose any pieces in the engine. But let me know if I'm wrong.
Thank you
Cas
Dec 22, 2019 at 10:25 AM
STEVE W.
  • 15,113 POSTS
3.5 is very low. That could be the entire problem. You should be able to measure 5 volts or very close to it. Measure between the Dark Blue wire with a Dark Green trace and the Pink with Yellow trace wire with the key on. You want to see 5 volts. Then go to the cam sensor and check between the Dk Blue w green trace and the Yellow wire with pink trace That should also show 5 volts. If not you have a problem. The Dk Blue wgreen wire is the ground side, the others are 5 volt reference feeds from two different connection pins. The other wire on each sensor is the signal output. If you find 5 volts at the cam sensor but still 3.5 at the crank sensor, take the negative probe and put it on the negative battery terminal and then measure the crank signal voltage again. If it's still 3.5 then the ground side is OK and the problem is on the feed side.
Dec 22, 2019 at 12:19 PM
CASMIHOK
  • 205 POSTS
Man, reading this stuff makes me feel like an idiot. I'll try.
If my wires are no good, is that something that you have to bring to a mechanic for? Or could I do it if I learned properly?
I don't know anybody around here or have a trustworthy mechanic
Thank you
Cas
Dec 22, 2019 at 1:13 PM
CASMIHOK
  • 205 POSTS
So sorry, just wanted to ask two questions
1. Is my crankshaft sensor busted now that I've been spraying so much PB Blaster
2. My battery needs to be replaced, is there any way this is causing the wiring problens? Advanced Auto told me its reading 575 CCA that's only 25 below 600 CCA tho
Dec 22, 2019 at 1:52 PM
STEVE W.
  • 15,113 POSTS
It shouldn't be unless it;s cracked. They are designed to be run in hot oil and corrosive gasses in the engine. The connector side is a bit less forgiving but a spray with some contact cleaner should get the PB out.
As far as the wiring, It would depend on what it actually is. If you measured the voltages and found one is 5 volts and one is 3.5 then it may be just a corroded connection at the PCM. Or it may be internal to the PCM. That was one reason I wanted you to measure them both and to ground as well.
That isn't that bad for a battery, it's showing some age but if it turns the engine over and reads 12.6 volts setting still it shouldn't effect the measurements. That's one of the reasons why the sensors use a 5 volt reference voltage. When you are cranking and engine the starter pulls a lot of power and that can draw the voltage down to 9-10 volts as it cranks. If they used a reference voltage of 10 volts it could easily cause problems as the voltage dropped lower. So they use 5 volts which they get by running a simple regulator inside the PCM. That lower voltage is safe because it's below what the draw should be and much of the PCM is nothing but a computer designed to run on 5 volts anyway.
Dec 22, 2019 at 2:19 PM
CASMIHOK
  • 205 POSTS
Okay. Thank you I'll try my best.
Dec 22, 2019 at 3:02 PM
STEVE W.
  • 15,113 POSTS
That's all that anyone can ask. If you run into issues just ask.
Dec 25, 2019 at 3:43 PM
CASMIHOK
  • 205 POSTS
Hi Steve, I hope you enjoyed your holiday! And a happy new year to all my friends at 2CarPros.
Still struggling over here with my sensor! I got my hands on a nice scanner tool, my buddy let me borrow it. It's a CPR 123. I used the scan tool on the Chrysler setting and tested the Cam Crank difference with the car running. It was jumping between 3.8 and 4.2 ish and it jumped to 4.6 when I revved the engine. Does that sound good? My father said he's confident it's the sensor. Because it is an intermittent code, he said he is confident it's the sensor stalling out on me. I know you're confident it's a wiring issue, what does that difference value mean to you?
I know I told you I got a 3.5 V reading on the connector and you said that it was low, but maybe it was inaccurate? Curious to hear your input on this, and this CPR 123 is new to me. I see a few other cam / crank options to test. Let me know if anything else would be useful to test. Thanks!
Cas
Jan 2, 2020 at 7:49 AM
STEVE W.
  • 15,113 POSTS
Intermittent codes can be wiring or part, that is why you test both. In this case I would say it's the wiring simply because of the readings you are getting and it being a Jeep that are known for wiring and ground issues. If you think the voltage was wrong, test it again. You should have real close to 5 volts there, low voltage will cause the sensors to work intermittently if they work at all.
Jan 2, 2020 at 10:35 PM
CASMIHOK
  • 205 POSTS
Okay, thank you Steve.
Jan 4, 2020 at 1:28 PM
STEVE W.
  • 15,113 POSTS
You're welcome. Don't give up on removing the sensor though, if you already have it so it will move a bit it would be a good idea to remove it, clean out the hole and replace it just because the poking and prodding may have caused a glue seam or seal to break loose. Beyond that keep us informed of what you find.
Jan 5, 2020 at 6:12 AM
CASMIHOK
  • 205 POSTS
So I finally got it out, and then got the new one in. I lubed it well with oil and I got some sand paper and smoother out the rust in the hole as well.
I took the car for a ride last night. Seems okay, I had the CPR 123 recording while I was driving. I'm not sure if I used it properly because I don't see much under review...
Regardless, I don't have any codes after my ride. I took it for a good 40 min drive, speeds up to 60. I would have gone faster, but at 2000 RPM it felt kind of rough. I would get really close within the 2000 and you can feel a struggle, then the RPM's would go down after almost seemingly failing to operate 100%. I don't know if I'm describing this correctly.
I thought maybe it was a misfire, I just avoided going to 2000 RPM on majority of my ride. When accelerating uphill from 0, it was pretty rough.
Given that there's no codes, and with this feeling - what can I look out for? What sort of tests could I run on this CPR 123 to help me out?
Thank you!
PS. Let me know if you'd prefer I start a new thread.
Jan 7, 2020 at 1:01 PM
STEVE W.
  • 15,113 POSTS
Good on getting it out. Sounds like it didn't cure the entire problem though. I would probably take it out and try running it a bit harder to see if it will set a code. I'd hate to tell you to pull the plugs and clean or replace them or try something else without any clue as to where the issue might be. 2000 rpm is nothing for that engine so there has to be another problem.
If the tool supports it try recording the misfire data numbers and the MAP and ECT. Jeeps can take a while to set misfire codes, so run it a bit where it struggles, even shift it down so it hits those rpms earlier and see if it sets a code.
Jan 7, 2020 at 2:42 PM
CASMIHOK
  • 205 POSTS
Valvoline "topped off" my trans fluid, seems to be too much in there. Maybe causing the grinding. I first attempted to get some to leak out my pan, but no luck there. I also got two bolt holes stripped when putting em back in. I'm pretty confident they were bad to begin with, because they barely got tight. All the other ones I had no problem with.
So, I had to cancel my tires mounting this morning. Today, Ill search for some tubing to siphon out some fluid. As far as my pan goes, would it be terrible to drive it a few miles with two bolts missing? I have to re-thread the female thread, and I have never done that before and not sure I can get that done today. I have a rescheduled appointment for my tires tomorrow morning though. What do you think? Can I drive without the bolts for a few miles?
Jan 8, 2020 at 7:57 AM
STEVE W.
  • 15,113 POSTS
You can but if they are close together you may get a leak. The easiest way would be to get a heli-coil kit in the correct size. They are available at most parts stores or even places like tractor supply or some lowes home depot places.
Jan 8, 2020 at 12:44 PM
LOVEMYPATHFINDER
The crankshaft sensor can still be bad and waiting hours between starting, engine will turn over but will likely stall out because of the failing sensor.
Dec 10, 2024 at 4:47 PM
STEVE W.
  • 15,113 POSTS
You said you smoothed out the rust, Did you chip away the thicker rust that was under the sensor? If not pull it out, plug the hole and use a chisel or similar to knock the rust off. Then put the sensor back in and see if it will go past 2000 rpm. For the pan you can Heli-coil it, or as the rest of the engine looks that rusted you could try a pair of self-tapping hex bolts in the next size up.
Dec 10, 2024 at 6:18 PM
