Runs rough and engine light blinks
2001 CHEVROLET BLAZER
201,000 MILES • 4.3L • V6 • 4WD • AUTOMATIC
ALYSSA SANCHEZ
So my truck has a problem starting after it rains and runs rough if you don’t drive it after about 10 hours. Well it wouldn’t crank after it had rained one day to I had to spray starts fluid in it to get it to crank after driving it for about 20 minutes I heard a pop and it started running really rough and started to smell like a burnt firework. I heard I need to replace my spark plugs and wires and it will be fine. But I’m nervous to drive it after that happened. Any ideas?
Jul 24, 2018 at 6:41 PM
Hi, Alyissa, and thanks for using 2CarPros.com.
A flashing light indicates a misfire. However, a misfire should not smell like something burning unless it backfired. Is that what happened?
As far as the check engine light, you can scan the computer to determine what trouble codes are stored. Here is a quick video which shows how. Also, most parts stores will scan it for free or lend you the scanner.
https://youtu.be/YV3TRZwer8k
Once you scan it, let me know what codes you get.
Here is a link showing how to replace spark plugs:
https://www.2carpros.com/articles/how-to-change-spark-plugs
Also, the idea of it not starting is usually related to plug wires. So, that could be the issue as well as the misfire.
I hope this is helpful. If you have other questions or need help, let me know.
Jul 24, 2018 at 7:35 PM
ALYSSA SANCHEZ
Thank you for responding. I have had the code checked and it said I had a misfire. But I am not sure if it backfired because I am not sure what really happens when a car backfires. All I know is that is started like stuttering after it happened.
Jul 24, 2018 at 7:40 PM
Hi Alyssia:
By any chance, do you know what codes were found? Also, here is a link that describes what a backfire is and what can cause it. Basically, if you were having trouble when it rained, something was getting wet in the ignition system. My guess is there was a build up of fuel in one of the cylinders because a spark plug wasn't igniting the fuel. When it finally did, you would have heard the backfire.
https://www.2carpros.com/articles/engine-backfires-while-running
I hope I'm helping and not confusing you.
Let me know if you have the codes that were found. They will be something like the following:
P0300
P0301
P0302
And so on. A P0300 means there is a random misfire. The P030... indicates which cylinder is missfiring. For example, P0301 indicates cylinder 1, P0302 indicates cylinder 2 and so on.
I will watch for your reply. Feel free to ask anything.
Jul 25, 2018 at 8:07 PM
