I don't have test equipment so I'm hoping you'll know.This truck will start and runs very rough and if you try to rev it,it gets worse. Shut it off then restart,it will run smooth.It has new plugs and wires,distributor cap and rotor,brand new.There is one vacuum line I cannot find where it should connect.I've looked at lots of videos but no match and shop manual doesn't show it.With it blocked off,it lowers the idle a bit.The run smooth after restart is biggest concern.Have you dealt with same issue?
Jun 11, 2021 at 2:37 PM
