Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Mazda
Protege
Engine
Symptoms
Lean
Runs lean
2000 MAZDA PROTEGE
180,000 MILES • 1.6L • 4 CYL • FWD • MANUAL
ZEMORZEMOR
MEMBER
FOLLOW
At idle long term fuel trim vary for 6.3 % to sometimes 14.2%. what could cause the problem?
May 14, 2017 at 7:10 AM
HMAC300
CERTIFIED EXPERT
vacuum leak, low fuel pressure leaky injector etc. scan for codes and check fuel pressure with a gauge. See link. auto parts rent gauge.
May 14, 2017 at 8:46 AM
ZEMORZEMOR
MEMBER
i forgot to tell you the oxygen sensor stays lean after i shut off the engine and started back .it will oscillate after i bleep the gas pedal
May 15, 2017 at 3:53 PM
HMAC300
CERTIFIED EXPERT
check what I said in first reply
May 15, 2017 at 4:36 PM
