Running Rough after tune up
1994 CHEVROLET TRUCK
205,000 MILES
E_DUTCHER
after tuning up my truck with new plugs wires cap and coil the truck is running rough and making a whining noise. when i open up on the throttle and close it quickly it almost dies
Apr 24, 2013 at 7:32 PM
sounds like you have a vacuum line off re check your work
Apr 24, 2013 at 7:39 PM
STEPHENS749
  • EXPERT
  • 12 POSTS
remove your dist cap and make sure the rotor button is not contacting the dist. the rotor may not be pressed down far enough.
Apr 24, 2013 at 7:40 PM
E_DUTCHER
one vacuum line was off that seemed to fix the check engine light a small adjustment to the timing seemed to fix the rough idle and driving when cold i will check on the cap and rotor tonight also i notice that my voltage gauge seems to be running lower than normal
Apr 25, 2013 at 7:13 AM
