Car acting like it was not firing on all cylinders?
2004 HYUNDAI SONATA
200,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
BFD1901
The other day I went down the road to meet a friend, instead of taking my normal route I took the short cut, and it was a hard ride cause the road was torn up meaning a lot of bumps, and gravel. When I came to my destination the car was acting like it wasn't firing on all cylinders or that a filter was clogged. At idle the car would misfire and jerk like it was going to shut off.
There are no check engine lights on, or codes being thrown.
I was able to get it home, but when trying to accelerate it was obvious that it wasn't getting all the power it had before. But once it warms up it runs a little better but still not like it should. I almost felt like the bumpy ride knocked a plug loose, or something. Please help. My dad asks if it could be a coil pack or simply fouled plugs. Please help.
Jul 17, 2023 at 6:26 PM
BFD1901
Edit*
There are no check engine lights on or codes being thrown.
Jul 17, 2023 at 6:28 PM
Yes, it could be misfiring, but it should have a code for it, I would do a full tune up if it has not been done in a while and if that does not help, I would suspect the fuel pump is going bad. Here is a generic guide to help you step by step with instructions in the diagrams below to show you how on your car:
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
NGK .................... PFR5N-11
CHAMPION .................... RC1OYCPB4
Gap .................... 1.0 - 1.1 mm (0.039 - 0.043 in)
Torque .................... 20 - 30 Nm (15 - 21 lb-ft)
Also change out the fuel filter which can help as well.
https://www.2carpros.com/articles/how-to-change-a-fuel-filter
Check out the images (below). Please let us know how it goes.
Jul 18, 2023 at 11:16 AM
