Suddenly running rough with a fair bit of smoke n strong smell of fuel. Starts easily but check engine came on and couldn't cancel alert for it.
Aug 25, 2019 at 5:19 AM
CERTIFIED EXPERT
It sounds like an injector is stuck on could have shorted out etc. You should be able to remove all spark plugs and the cylinder with the wet/black plug will be the culprit. Here is a guide to help you test the injector once you have removed it:
