Running rich
2013 JEEP WRANGLER
67,000 MILES • 3.6L • V6 • 4WD • AUTOMATIC
JKLANTELME
It brought up the code for a cylinder misfire. I changed the ignition coil and all six spark plugs. Is running fine but I’m still getting a rich smell and some smoke from the exhaust. There was still a little oil around the manifold, will it take some time for it to burn off and the smell will leave or do I need to focus on another area?
Dec 7, 2019 at 5:04 AM
AL514
  • 5,465 POSTS
It sounds like you may have a fuel injector that's leaking, causing a rich condition. You can try unplugging each injector one at a time and see if it alleviates the problem. The engine will run a little rough while doing this but it will help find out if it's actually an injector staying open. You should also have the ECM scanned for diagnostic codes.
https://www.2carpros.com/articles/excessive-smoke-coming-from-the-exhaust-pipe
https://www.2carpros.com/articles/engine-black-smoke
https://www.2carpros.com/articles/how-to-test-a-fuel-injector
Dec 7, 2019 at 10:05 AM
