Will not stay running
1996 CHEVROLET CAPRICE
196,000 MILES • 2.2L • 4 CYL • 2WD • MANUAL
ANDREWSEAN76
I am using starting fluid to get my truck running and after a few seconds it cuts back off. when I spray it again it starts all over again. what could be the problem?
Apr 4, 2021 at 4:43 AM
Good morning,
This sounds like a fuel delivery issue from a possible bad fuel pump. You need to let the pressure. You can rent a tester at a parts store to verify the fuel pump.
With the ignition "on" and the engine "off" (zero vacuum), system fuel pressure at the pressure test connection should be 284-325 kPa (41-47 psi).
I also attached the wiring diagram of the system for you. You need to check the fuses and the relay for power.
Apr 4, 2021 at 5:11 AM
