Login
Join
Home
Answered Questions
Repair Topics
Repair & Service Guides
Popular Questions
Warning Lights
Trouble Codes
How It Works
Testing / Diagnostics
Symptoms
Videos
Login
Become a Member
Home
Oldsmobile
Delta 88
Engine
Symptoms
Misfire
running on 3 cylinders
1986 OLDSMOBILE DELTA 88
112,000 MILES
JBAALMANN
MEMBER
1 POST
FOLLOW
replaced coil pack module spark plugs and wires no spark on 3 cylnders.
May 17, 2013 at 8:48 PM
ERNEST CLARK
CERTIFIED EXPERT
From the beginning, what directed you to a "No spark" condition on cylinder 3?
How are you checking for the "No spark" condition on cylinder 3?
Did you use dailectric grease inside the plug boots on both ends?
Also, check the wiring/connectors leading to the coil pack, specifically for that cylinder.
Jun 11, 2013 at 11:54 AM
