Hey DANNY ZACCARDI,
Have you checked the bulb?
You will have to remove the tail light which should be easily done by removing 2 bolts on the interior of the tailgate opening. You then gently pull the light and it will release from the body.
Compare to the other side to identify which bulb is out and remove the bulb that is not working to inspect.
You should be able to see the filament in the bulb melted or some burning marks on the glass of the bulb.
Replace the bulb and see what you get.
Regards, Joe
Feb 12, 2020 at 6:25 PM
