Front and back running lights not working
1996 DODGE DAKOTA
123,000 MILES • 3.9L • V6 • 2WD • AUTOMATIC
HANNAH PAPPS
We can't figure out how to get the running lights to work on it the head lights work the blinkers and the brake lights work, but the front and back running lights don't. we have replaced the fuses and bulbs can't figure it out. please help
Mar 17, 2020 at 8:36 AM
Good morning,
There is a fuse for the parking lights. I have attached a wiring diagram for you to view.
Check the fuse for power on both sides. This is a power test, not a visual test.
The next stop is the headlight switch. Make sure there is power to the highlighted wire to the headlight switch.
Dec 3, 2020 at 9:58 AM
GOLIASTRO
rear parking lights won't work on a 1996 Dodge Dakota. Turn signals work, and front parking lights work.
Dec 3, 2020 at 10:11 AM (Merged)
Check the wiring on the driver's side near the end of the frame. Also, if the wiring is good, check the headlight switch and all fuses.
GOLIASTRO
The rear lights have power when tested, but are not working. Is the ground wire the problem, and where is the ground wire located?
Dec 3, 2020 at 10:12 AM (Merged)
If you are getting power using a seperate test light, it could be a bad ground or the socket may be worn and the light itself isn't making a good contact inside. Check that.
EILEEN TILLEY
The brake lights don't work, headlights, taillights don't work, ABS light is on, door locks don't work, Brake light is on tachometer (sp?) don't work. Gas gage don't work. We have checked all fuses and they are good, put new headlight switch in, checked all power lines and we are getting power..not sure where to go from here?
CARADIODOC
  • 34,306 POSTS
Lets start with an easy circuit and hope all the dead circuits have a common cause. Go right on the brake light switch and use a test light to check for 12 volts on one wire all the time, and 12 volts on the switched wire when you press the brake pedal. I'm going to search for a service manual to see the wire colors you're after.
CARADIODOC
  • 34,306 POSTS
I found the wiring diagram. The first wire you want is pink / dark blue. That must have 12 volts all the time. Next is the white / tan. That one must have 12 volts when you press the brake pedal.
TJN2010
1995 Dodge Dakota
how do i fix my tail lights they just went out and dont work when i press the brake?
If the bulbs are good, check the brake light switch. It's attached to the brake pedal under the dash. Make sure you are getting power to the switch, and when the pedal is depressed, you have power out. Also, did you check the fuse?
Let me know what you find.
L.W.JONES
  • 10 POSTS
When I turn on my headlights I do not have dash lights or tail lights or running lights.
It sounds like you have a headlight switch that has failed, please check all fuses first here is a wiring diagram and guide that will help with the testing. See the image below.
Please let me know what you find
Best, Ken
L.W.JONES
  • 10 POSTS
Yep that is what I thought, thanks
L.W.JONES
  • 10 POSTS
Is it just a plug in deal ?
Yes it is, car repair late night! only on 2CarPros, please let me know if you need anything else we are here to help.
Best, Ken
L.W.JONES
  • 10 POSTS
Will do thanks.
