Running hot only while A/C is on
2006 CHRYSLER 300
63,000 MILES • 2.7L • 6 CYL • 2WD • AUTOMATIC
TRA
  • 41 POSTS
My car ran hot only while the A/C was on one day recently. I looked up some things. Think I know what it is. But, can you first tell me if since a supposed mechanic put 100% concentrate antifreeze in my car a while back(and I do not drive a lot because I work from home). Can that cause this? What effects can that 100% have on the car and its parts? What effects can that 100% have on the car and its parts?" And can it eventually cause the fans to stop turning?
Aug 17, 2018 at 6:50 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
I responded to you your question. Did you not receive the answer?
Thanks for using 2CarPros.
Danny-
Aug 18, 2018 at 6:15 AM
TRA
  • 41 POSTS
No I did not Danny. Did you answer on another site?
Aug 19, 2018 at 5:36 PM
DANNY L
  • 5,648 POSTS
Hello again.
Having a 100% concentrate of antifreeze will not harm an engine or the engine components nor make the fans not work. The optimum ratio for antifreeze is mixed 50-50 with water. There is only a slight chance of running hot because of the mixture. If the level is low just dilute by adding water. Hope this helps and thanks for using 2CarPros.
Danny-
Aug 21, 2018 at 6:07 PM
TRA
  • 41 POSTS
Yes, have already been stamping that down with water as I could. Thanks for the help.
Aug 22, 2018 at 9:11 AM
DANNY L
  • 5,648 POSTS
Hello again.
Thanks for using 2CarPros and feel free to ask anything more if needed.
Danny-
Aug 22, 2018 at 5:21 PM
