Running hot, lots of work done, no joy
2002 MITSUBISHI ECLIPSE
109,000 MILES • 2.4L • 4 CYL • 2WD • AUTOMATIC
DANNYP.
  • 5 POSTS
Mostly stock.
Car had been running sort of hot but not completely overheating, for a while.
The timing belt and water pump are about a-year-old and were changed proactively.
Since the engine had been running hot, I went ahead and pulled the head and had it checked and re-surfaced. It was about 0.007 out of spec, but one of my manuals states the head can be out 0.008. The old gasket did not have an obvious sign of being blown through. While the head was pulled, I polished all the valves and valve seats. Also changed the valve seals. It’s only a four cylinder but it does feel like the acceleration is back to what it was when it was new.
I have made sure that all of the air is purged so that only coolant is flowing.
I should have performed a leak down test before taking the head off, but i did not. I did perform a couple of leak downs after replacing the head gasket. I used about 90 psi pressure and the rings are leaking a little bit which is fine. All four cylinders are losing about 12%. I did not hear any noise coming from the intake or the exhaust manifolds. No bubbles appeared in the coolant and I left the leak down running for a while on each cylinder, heck I even did that a couple times. No bubbles.
I’ve already sent the PCM off to the folks at NEAT Computers have it checked and they said that it was in perfect condition so I reinstalled the PCM. Of course, they recommended that I check the engine coolant sensor and the fan control module.
I tested the coolant sensor using a pot of hot water on the stove and the results seemed okay. The coolant sensor is aftermarket, so this week I’m going to go to the dealership and pick up one that is factory. In the third and fourth points below, I note the temperatures that the PCM is providing based on the engine coolant sensor resistance so it seems like the engine coolant sensor is working properly. Regardless I will change it with one from the dealer.
I think the fan controller is okay based on the results below, but I’m curious to see what you think.
- The voltage at the fan control module from the PCM is about 0.04 V when the fans are not running.
- The fans will both run and receive 5.1V from the PCM when the air-conditioner is on. Both fans run out of very strong pace with this voltage.
- If I just let the engine run with no heat being pulled on the inside of the car, then the engine will gradually warm up. Eventually it will reach about 208° according to my Bluetooth OBD reader app. At that point, the fans will kick on and will receive about 2.3V from the PCM, both fans run at a LOW speed until the engine temperature drops to approx 203° and the fans turn off. It would do this over and over again if I let it.
- When I unplug the coolant temp sensor, then both fans will start and run at full speed. The voltage from the PCM at the fan controller is 5.1 volts. My OBD Bluetooth reader will go from showing the engine temperature to showing -40°F. I can plug the coolant sensor connector back into the sensor, but the fans will continue to run at full speed until I clear the P0171 code or restart the car. When I plug the connector back in, the engine temperature will return to normal in my app.
- If I let the car climb to 208° and then unplug the coolant temperature sensor the fans will kick on at a high speed and within a minute the engine temperature will drop to about 195° and will stay there as long as the fans are running.
I’m thrown off here because with my Bluetooth OBD reader I’m able to see the temperature of the engine based on the engine coolant sensor. So if I am able to see the engine temperature that means I’m getting the temperature from the PCM. The obd reader app shows the engine temperature drop to the fake -40° when I plug the engine coolant sensor. It just seems like if I can see the engine climb to 208° then the PCM should see that as well and turn the fans on long before that high temp is reached.
Mar 3, 2019 at 2:49 PM
Good afternoon,
Take the temperature of the top and bottom of the radiator when the engine is at 200 degrees. Tell me what the temperatures are.
Mar 3, 2019 at 3:37 PM
DANNYP.
  • 5 POSTS
Thanks.
I should have mentioned that I tested the existing unbranded aftermarket thermostat a few weeks ago and it seemed slow to open, so I bought a new thermostat that is an AISIN brand. The new thermostat is built better and has the air bleed jiggle, the aftermarket did not. I tested the aftermarket and new thermostat in the same pot and the new thermostat opened earlier, so the AISIN was installed last week.
Yesterday, I pulled the radiator mounts from the core support to see if there was any trash between the radiator and the condenser. It was clean.
I measured the four corners of the radiator on the backside, with one of those cheap temperature guns.
The car was cold and the engine temp climbed steadily to 195.8. The temp seemed to stay at 195.8 a little while, I assume because the thermostat opened and the cooler coolant from the radiator started to flow.
I tried to capture the temperature from the four corners as the engine temp hit 197.6°F, 199.4°F, and 201.2°F.
Engine temperature 197.6°F
Driver top 186
Driver bottom 186
Passenger top 182 (possible bad angle)
Passenger bottom 186
Engine temperature 199.4°F
Driver top 190.8
Driver bottom 190
Passenger top 192.3
Passenger bottom 178.5. (Possible bad angle when measuring and the coolant exits on the opposite/drivers bottom corner)
Engine temperature 201.2°F
Driver top 191.6
Driver bottom 193.9
Passenger top 194.6
Passenger bottom 187
Mar 4, 2019 at 2:14 PM
There is no cooling from the radiator. The temperature at 198 at the top should be around 150 on the bottom.
You have a clogged radiator.
Mar 4, 2019 at 2:18 PM
DANNYP.
  • 5 POSTS
But the fans were not running when I measured, since the fans only start around 206 degrees. Are you thinking that the radiator would provide cooling even if the fans do not run even when the car is parked? I can manually run the fans by unplugging the engine coolant sensor.
Mar 4, 2019 at 2:57 PM
That can be from that thermostat you are using. You should not use the one with the bypass at all. You should use the OEM.
If you trigger the fans, does the engine cool down on its own?
Mar 4, 2019 at 3:02 PM
DANNYP.
  • 5 POSTS
From 203-206 degrees, if I unplug the engine coolant sensor then the fans will start and run on high (5 volts from the PCM). The engine temperature will drop to 195 within one minute and stay there as long as the fans are running.
Mar 4, 2019 at 3:07 PM
It should drop to at least 180.
Back to the radiator and that thermostat should be replaced.
Mar 4, 2019 at 3:08 PM
DANNYP.
  • 5 POSTS
Okay, will try that. Thanks.
Mar 4, 2019 at 3:12 PM
You are welcome.
Always glad to help.
Mar 4, 2019 at 3:14 PM
