Running hot
2004 CHEVROLET TRAILBLAZER
175 MILES • 4.2L • 6 CYL • 4WD • AUTOMATIC
ROSALYN36
I replace a thermostat and water pump on my truck. When i drive it it is fine, but if i drive a long period of time it gets hot and i have to pull over to cool down and i can hear the water boiling in the coolant bowl. It leaks out coolant on the passenger side on the ground. Can it be my heater core?
Jul 21, 2019 at 2:01 PM
Good evening,
Where is the leak located? Is it from the surge tank cap?
https://www.2carpros.com/articles/engine-overheating-or-running-hot
Pressure test the system to determine the leak.
https://www.2carpros.com/articles/radiator-pressure-test
Jul 21, 2019 at 4:11 PM
ROSALYN36
It is located under the car by the coolant bowl, but you can see it on the side of the right tire on the passenger side. i have a video of it.
Jul 21, 2019 at 8:54 PM
That is too general. I cannot see where it is leaking.
You need to do a pressure test as I suggested and look under the hood for the leak. Then post you video for me to view.
Jul 22, 2019 at 5:21 AM
