With the key in the run position is the security light on solid or flashing?
Sep 18, 2016 at 9:34 AM
CHERYL FRAZIER
MEMBER
flashing.
Sep 18, 2016 at 9:42 AM
SATURNTECH9
CERTIFIED EXPERT
Try the steps I posted also your gas gauge is working now?
Image (Click to enlarge)
Sep 18, 2016 at 9:48 AM
CHERYL FRAZIER
MEMBER
yes,, gas gauge is working.
Sep 18, 2016 at 10:05 AM
SATURNTECH9
CERTIFIED EXPERT
OK let me know what happens.
Sep 18, 2016 at 11:02 AM
CHERYL FRAZIER
MEMBER
I am so sorry, the gas gauge is not working.
Sep 18, 2016 at 12:09 PM
CHERYL FRAZIER
MEMBER
Thank you so much for your input. No, it didn't work but I give you some wrong info. It did however lead us to the problem and we do have it running. Again, thank you so much. Have a wonderful day.
Sep 18, 2016 at 4:49 PM
SATURNTECH9
CERTIFIED EXPERT
So what was the problem?Because if the gas was inop and it cranks and doesn't start then most likely you have a bad body control module.I have replaced tons of them with those symptoms no start and fuel gauge inop intermittent.
