Car runs hot if sitting, pull off and it starts to cool.
Oct 6, 2016 at 7:43 AM
HMAC300
CERTIFIED EXPERT
check your fuses and cooling fan relays under hood fuse box that may be the problem unless it runs hotter than normal when moving down road. also check coolant level if low then fill to full and have it pressure tested for a head gasket leak.
