Rubbing sound in front end?
2000 NISSAN SUNNY
200,000 MILES • 2WD • MANUAL
GAYANM
Rubbing sound hear from front end when drive almost 15 to 20 km.
Jun 3, 2023 at 9:30 AM
Can you please shoot a quick video with your phone so I can hear the noise? that way I can tell for sure what's going on.. You can upload it here with your response.
Jun 3, 2023 at 11:40 AM
NISSANEGYPT
Here are some potential causes and fixes for a rubbing sound from the front end when driving a 2000 Nissan Sunny:
- Worn brake pads
- Sticking brake caliper
- Wheel bearing issue
- Suspension issue
- Bent rim
- Misaligned wheels
The rubbing is most likely being caused by worn brake pads or a wheel/suspension issue if it's coming from the front. Start by thoroughly inspecting those components. Test driving after each fix to verify the sound is gone.
Sep 18, 2023 at 10:40 PM
