rubbing and vibration in front when slowing down
2003 DODGE CARAVAN
203,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
JACKYE TACKETT
i am just noticing a vibration when going over forty five mph and a rubbing and more pronounced vibration when braking in the front end passenger side. i have all new tires and the air pressure is right in all. its making it hard to slow down in time and i am unsure if it is safe to continue to drive any advice would be appreciated
May 10, 2017 at 10:17 AM
STEVE W.
  • 15,113 POSTS
The description sounds like either bad brake pads (worn out, or damaged) or a wheel bearing issue. Both should be looked at and repaired ASAP.
May 10, 2017 at 10:46 AM
JACKYE TACKETT
i just had new brakes put on six months ago and the van sat for four months. could this be a rotor or something simple?
May 10, 2017 at 11:47 AM
STEVE W.
  • 15,113 POSTS
If it sat four months it could easily be rusty rotors causing it. Especially if you are in an area that has been raining or the last time it was driven it was in snow/salted roads, then parked.
May 11, 2017 at 4:16 AM
