How to remove and replace the Automatic Transmission Shifter Cable?
2012 NISSAN VERSA
85,000 MILES • 1.6L • 4 CYL • 2WD • AUTOMATIC
JONSOLOW13
  • 133 POSTS
Can you send us the instructions (with diagrams if possible) for removal and replacement shifter control cable for the car listed above?
Thanks, as usual,
Jon
Nov 21, 2023 at 9:27 AM
Sure, it looks like the shifter cable is going to need to be removed from the transmission first and then pulled through the interior after it is disconnected from the shifter itself. Check out the images (below). Let us know if you need anything else.
Nov 21, 2023 at 5:58 PM
JONSOLOW13
  • 133 POSTS
Thanks, and Happy Thanksgiving!!!!
Nov 21, 2023 at 8:39 PM
You are welcome, happy thanksgiving!
Nov 23, 2023 at 9:33 AM
