rpm's surge only when engine is warm
2001 SATURN SC1
156,600 MILES • 1.9L • 4 CYL • 2WD • AUTOMATIC
IKE13
  • 12 POSTS
This problem just started about one week ago. Whenever I am stopped and my engine is idling and only while it is running at normal operating temperature does it surge. When its cold it does not have this problem. I had it tested at an auto parts store and the code that reads is P0340 camshaft position sensor A. Is this the cause of my rpm's surging?
Dec 2, 2017 at 10:10 PM
JIS001
  • 3,412 POSTS
That would not cause the surge. I would recommend you clean the idle air control valve or replace it.
Dec 3, 2017 at 2:16 AM
IKE13
  • 12 POSTS
I already cleaned and replaced that valve. That worked for the RPM's spiking to 3000 RPM's on start up and accelerating by itself. It just seems odd that it only does it when the car is hot.
Dec 3, 2017 at 5:27 PM
JIS001
  • 3,412 POSTS
Check for a vacuum leak. If no leak then I would just replace the idle air control valve.
Dec 3, 2017 at 6:16 PM
IKE13
  • 12 POSTS
I promise you it's not the IAC valve or vacuum leaks. And it only does it while the car is hot
Dec 4, 2017 at 9:42 PM
I would try the camshaft sensor since it has a code for it. Here is a guide that will show you what you are in for when doing the job.
https://www.2carpros.com/articles/camshaft-angle-sensor-replacement
Please let us know what you find.
Dec 7, 2017 at 6:36 PM
