Rpm's sticking
1993 FORD F-150
270,000 MILES • 4.9L • 6 CYL • 4WD • MANUAL
JGANAWAY
  • 42 POSTS
Occasionally, the rpm's will stay around 2,000 rpm's for about 30 seconds or so when the clutch is pressed. While driving when this happens, if I turn the ignition from run to on (not completely off), and back to run the rpm's drop like they are supposed to. I have replaced the IAC, TPS, MAP sensor, vacuum lines, EGR, intake temperature sensor, coolant temperature sensor and recently, replaced the oil pan, valve cover, throttle body, upper and lower intake/exhaust manifold gaskets. I'm stumped.
Jul 29, 2020 at 6:10 AM
Good morning,
Wow, lots of parts with no result.
Did you check the cables to the throttle body to be sure they are free and not sticking?
https://www.2carpros.com/articles/engine-idles-too-high
I would disconnect the cables and rev the engine manually and see if it still hangs up.
Jul 29, 2020 at 6:50 AM
