RPMs reving way up, when in neutral
2001 FORD ESCAPE
200,000 MILES • 2.0L • 4 CYL • 2WD • MANUAL
SMARTIN906
just had the plugs and wires replaced, every since the idle has been whacked ! the RPMs shoot up when ever I am in neutral and the only way to stop this is to put the truck in gear... after a little while and when in neutral again ( like at a red light) the RPM's go way down... almost sputtering out completely....
Mar 25, 2015 at 1:04 AM
Check to make sure no vacuum hoses were knocked off. Also, check the idle air control valve on the throttle body.
Mar 25, 2015 at 5:41 AM
