Rpm issue
2003 BUICK REGAL
210,000 MILES • 3.8L • V6 • 2WD
NEEDFORSPEED1
My car is the IS 3800 series and it has an rpm issue. when I drive the gauge goes from 2000 to 5000 rpm. This causes a kick in the car. it clears up after it warms up but still jumps. also, when car is cold I have a single misfire when warming it up. i have done everything for preventive maintenance, spark plugs, etc. Do you have a solution for this problem? Thanks, Shane
Nov 5, 2017 at 1:09 PM
It sounds like the transmission is slipping i would check the fluid level. If it seems like I am way off base can you please take a quick video and upload it here to the site?
Nov 6, 2017 at 2:37 PM
NEEDFORSPEED1
I have checked my transmission oil.it is clean and full..probably will spray the intake and go from there....any other ideas....shane....
Nov 18, 2017 at 9:54 PM
You can upload a video here at the site using your phone. It is difficult to tell what's going on unless I can see it and hear it.
Lets try running the codes to see what come up
Please let us know what you find.
Nov 19, 2017 at 12:21 PM
