RPM too high
2001 CHRYSLER PT CRUISER
147,000 MILES • 2.3L • 4 CYL • 2WD • MANUAL
AURAGAL
My car has a RPM of 3 when traveling at seventy mph and realized that while driving a different vehicle at the same speed but shows RPM of 2. what would be the issues with it and how can it be fixed?
Mar 17, 2018 at 8:08 AM
Did you do the suggestions I gave you in your other post??
Mar 17, 2018 at 11:23 AM
AURAGAL
I do not know which post your talking about. my question is the first post i have written on this site.
Mar 17, 2018 at 2:33 PM
sorry, must have had an identical response for the same type of car.
look for vacuum leaks from any hoses on the motor. a vacuum leak will cause this issue.
the throttle body can be dirty not allowing the plate to totally close as well. clean it with some carburetor cleaner on a rag. make sure all the carbon is gone.
lastly, there is an idle air control valve that controls engine speed. if this was an issue it would turn on the check engine light and set a code.
Mar 17, 2018 at 4:00 PM
