RPM is high when the gear is in park and neutral position
2000 MITSUBISHI ECLIPSE
160,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
SEBASTIAN_PERSONAL
  • 77 POSTS
I just replace a new TPS, MAP, and Air Control Valve sensor. Yesterday, I also had a mechanic shop put in a new oxygen sensor. When I start up the motor and its in Park or in a neutral, it sounds like the RPM is higher pitch than normal, but when I put it in first gear or reverse, it goes back to a normal rpm pitch. Please help and thanks!
Feb 19, 2015 at 12:35 AM
MHPAUTOS
  • 31,937 POSTS
You may have a vacuum leak at the inlet manifold, do you have access to a scanner with live data? can you give me some accurate RPM readings at idle and in gear?
Feb 19, 2015 at 3:26 AM
SEBASTIAN_PERSONAL
  • 77 POSTS
Thanks! the RPM meter goes up to #2 in my dash board and when I put it in drive and reverse. It goes down to below # 1. Yes, I do have access to a live data.
Feb 19, 2015 at 6:26 AM
MHPAUTOS
  • 31,937 POSTS
I would be looking for a vacuum leak first, spray a little brake clean around the manifold a the engine will rev up if you hit a vacuum leak.
Feb 19, 2015 at 2:02 PM
