My truck randomly stopped working not too long ago. I changed the mass air flow sensor and fuel pump and it seemed to do the trick but when I would start the truck the rpm would drop so low it almost died and then it goes back up. It idles fine in park but when I put it in reverse it would do the same thing and try to die but the rpm wouldn't go back up. It would sit at about 200 RPMs. When I'm in drive and not moving it would also idle at about 200-300 RPMs. I just changed my fuel filter, and it stopped it from almost shutting off when started and when I put it in reverse. But it still idles low when in reverse. Is it supposed to idle low in reverse and if not, what could be causing it? I really appreciate the help.
Jan 29, 2023 at 1:29 PM
