RPM fluctuating while at speed
2014 RAM 1500
126,000 MILES • 5.7L • V8 • 4WD • AUTOMATIC
CORY SHANAHAN
  • 6 POSTS
Hello, I have the truck listed above Big Horn model. I have cleaned the Throttle Body and MAP sensor. Tune Up with Laser Iridium plugs and coil over boots. Just got a transmission service on my ZF 8-Speed, new pan/filter and oil. The issue I’m having is strange RPM fluctuations most noticeable around 20 mph-50 mph then less noticeable beyond that point. I have no codes or light not even stored codes. However I do have the typical HEMI manifold tick which I’m thinking that manifold leak maybe the issue but I feel like a leak that bad would cause a code particularly if the air to fuel ratio is off. Only MODS on the vehicle are a oil catch can, muffler and res. delete, and a SnB cold air intake.
Aug 2, 2019 at 5:01 PM
Welcome to 2CarPros.
When you modify today's vehicles, anything can happen. If you have a live data scanner, can you tell me the fuel trims? Also, have you checked for engine vacuum leaks? How bad is the manifold leaking? That can create a false lean mixture message to the computer.
Aug 3, 2019 at 9:22 PM
CARADIODOC
  • 34,306 POSTS
I'm sitting in the same truck with the same engine as we speak. JACOBANDNICKOLAS is right about modifications. I just wanted to add a comment about cold-air intakes, then I'll let you guys figure this out. The goal of all intake systems is to warm the air so the fuel will vaporize. Liquid gas will not burn. In fact, it will put out a lit match. Gas has to be in vapor form to burn. Years ago, we used a choke to force a real lot of gas into the engine in hopes a high enough percentage would vaporize to make the engine run right. Most of it went out the tail pipe, wasted, as a liquid, then vaporized in the hot exhaust system where it didn't do any good.
Cold air intake systems are like running with the choke on. The advertising fallacy is cold air will be more dense, so there's more of it getting packed into the cylinder, then you can add more gas to get more power. Well, the rest of us do the same thing by pushing further on the accelerator pedal. Diesel engines are different. With those, the throttle is wide-open all the time to take in as much air as possible. Engine speed is controlled by how much fuel is injected into the cylinders. With gas engines you have to stick to a 14.7 : 1 air / fuel ratio, by weight, for best power and fuel mileage, and lowest emissions. You lose on all counts when anything alters that mixture. Diesel engines usually use an inter-cooler to cool the intake air because they use turbochargers. Squeezing the air that way heats it up a lot, and that would promote engine damage and / or overheating. The 2,000 plus pounds of fuel pressure is what causes diesel fuel to vaporize as soon as it enters the cylinder. Gas is injected into the intake manifold runners where it has a little distance to travel which gives it time to vaporize. Cooling the intake air impedes the ability of the gas to vaporize, and that is the last thing you want to.
Chrysler was the only manufacturer that never needed a mass air flow sensor to make their engines run right, but I found that my truck does use one now. As such, there can not be any air leaks between that sensor and the throttle body. If any air sneaks in that doesn't go through the sensor, it won't be measured, and it won't be included in the fuel metering calculations. Leaks in this fresh air tube has been a common source of engine running problems on all other brands of cars and trucks for many years. I don't know why Chrysler's engineers chose to give up on what worked really well since the mid '80s, but now we have the same potential problems to look for as everyone else. In the past, vacuum leaks just resulted in increased engine rpm without a corresponding increase in power. Now, with a mass air flow sensor in the system, vacuum leaks will show up as a lean condition at the front oxygen sensors, and the Engine Computer trying to correct something it has no control over.
Good luck to you fellows. I'll be watching to see if this gets solved.
Aug 3, 2019 at 10:23 PM
CORY SHANAHAN
  • 6 POSTS
JACOBANDNICKOLAS. My friend that is a very good mechanic said the fuel trims looked fine on the live data scanner when he checked. The manifold leak is pretty bad it ticks very loud on a cold start up and I feel as if I still hear it slightly when driving next to a wall. I haven’t really checked for vacuum leaks since I’m not sure exactly where to look. So far I cleaned the Throttle Body twice in 7 months the first time was dirty the most recent time it wasn’t bad at all. I use Premium gas always 93 and synthetic oil on every oil service. I always check my oil catch can about once a week. I do drive the truck hard or “sporty” just hard acceleration but no burn outs or racing. Lots of highway miles so prolonged driving at 77 mph. The truck now has 126,384 miles on it. Also cleaned the PCV valve which wasn’t bad due to the catch can and cleaned the MAP sensor as well. My volts stay around 13-14 but lights do dim from time to time when I’m parked and over roll my windows up so not sure if the alternator maybe getting weak.
Aug 4, 2019 at 9:39 AM
CORY SHANAHAN
  • 6 POSTS
This is a cold start up hopefully the video attaches .
Aug 4, 2019 at 9:41 AM
CORY SHANAHAN
  • 6 POSTS
This is the RPM's at 45 mph on cruise control without touching the pedal at all. You may have to zoom in while watching. Been like this for 2 weeks still with no light or stored codes of any kind.
Aug 4, 2019 at 9:45 AM
CARADIODOC
  • 34,306 POSTS
The engine will run better on the correct 87 octane gas. Higher octane gas does not develop more power. The opposite occurs. Higher octane gas is much harder to ignite. That's the purpose of the higher octane. Being harder to ignite, it is less prone to pre-ignition, or spark knock, in high-compression engines. The use of high-octane gas allows engineers to design an engine that can produce more horsepower, but the higher power comes from the higher compression ratio, not the higher octane. The higher compression ratio is what leads to pre-ignition from higher cylinder temperatures. That is how diesel fuel is ignited, but it must be avoided in gas engines. That's where the higher octane rating is needed.
For your alternator, it is physically impossible for one to become weak. To have reduced output capacity, you would have to remove some of the copper wire from the stationary "stator" windings. Now that I shared that, it is possible, and not uncommon for one of the six internal diodes to fail, then you will lose exactly two-thirds of its output current capacity. For our model, the standard alternator is a 180-amp unit. That is really huge when you consider the optional upgraded alternator for my '80 Volare is a 55-amp alternator. Regardless, the next rule of alternators is they will only develop exactly what the electrical system needs, and no more. The 180 amps is the maximum it is capable of, and the only time you'll get that much is during a professional full-load output current test, which takes all of a few seconds to perform.
If your alternator has a failed diode, the most you'll be able to get during that full-load output current test will be 60 amps. Technically, that is not a "weak" alternator. It's an alternator with 2/3 of it not working. You can say the output is weak, and that can cause the symptoms you described. Another part of the professional charging system test measures "ripple" voltage. When you have a failed diode, you'll be missing one of the three output phases. Output voltage drops significantly during the time of that missing phase. That is what is being measured as ripple voltage. Most testers just show it on a relative bar car chart as "low" or "high", but a few that can make printouts actually show it as a voltage. If testing shows you have one third of normal output current and ripple voltage is "high", you have a failed diode. It's isn't really practical to try to replace diodes. The better repair is to just replace the alternator.
When you have a good alternator, the only other way to have weak output is if the belt is slipping over the pulley. You should hear the belt squealing then.
Aug 4, 2019 at 7:02 PM
CORY SHANAHAN
  • 6 POSTS
CARADIODOC, okay with that said I have absolutely no squeaks and I just replaced the belt to a Gates belt so that’s solid. As far as the gas is concerned that makes sense granted I have been using it for 7 months since my last Throttle Body cleaning and just now started having the issue. The reason I switched was because the Throttle Body got so dirty last time. Did the videos shed any light on what could be going on? Do you believe it is the gas or manifold leak? Sorry for all the questions just need this truck to last and don’t want to kill a perfectly good engine over something simple to fix. Trust me I would love to spend less money on gas if that’s the issue here, hahaha.
Aug 4, 2019 at 7:32 PM
CARADIODOC
  • 34,306 POSTS
Unfortunately my computer isn't smart enough to play videos, but engine performance really isn't one of my specialty areas. I was in tv / vcr repair for 40 years, and was an alignment specialist at a very nice Chrysler dealership all through the '90s. I taught Automotive Electrical and Suspension and Alignment for 9 years, so I have a lot of answers at the ready related to those things. That's why I jumped in and butted in to your private conversation with my "comments of value".
When I started at the dealership in late '89, we did see a lot of Caravan 3.0L engines with the air bypass passage around the throttle blade plugged with carbon. The result was an inability of the computer to bring idle speed up to the desired speed. With the better additives in even the cheapest of gas today, we haven't seen that problem since around the mid '90s. It never seemed to be an issue with any of the other engines.
From what I read here when people solve a problem by cleaning the back side of the throttle blade, it seems to be mostly related to a stumble or hesitation on acceleration, and my feeling is it seems to be more so on GM vehicles.
Also, for your reading excitement, the instructor at one of the Chrysler classes I attended discussed a couple of problems in the early years of fuel injection on truck engines. One was related to running fuel pressure too low, as in around 14 pounds. Gas will not burn in liquid form. Spraying it from an injector causes it to atomize and turn to a vapor by the time it crosses the intake runner and enters the cylinder. One problem they had was when the gas hit the cold intake valve face, it condensed back to a liquid, then burned very poorly in the cylinder. You got stumbling, poor throttle response, and low power for the first few minutes until the engine warmed up, then it ran fine. The fix for that in later years was to increase fuel pressure to over 45 psi, which is what almost all engines run today. The gas vaporizes better at that pressure, and has little tendency to condense back to a liquid.
The other problem was carbon build-up on the back side of the intake valves. Fuel would actually soak into that carbon, then it would be released as the engine warmed up. As I recall, that led to excessive emissions under certain conditions, but I don't remember any running problems. The fix for that was to run upper intake or combustion chamber cleaner through the engine to remove the carbon build-up. Those days are gone too with the better detergents and other additives in gas today.
Aug 4, 2019 at 8:36 PM
CORY SHANAHAN
  • 6 POSTS
So quick update: fixed the manifold gasket leak and that did not correct this RPM issue. So with that ruled out what is my next step? Change throttle Body and pedal so both sensors are new together and relearn them?
Aug 8, 2019 at 6:33 AM
CARADIODOC
  • 34,306 POSTS
If you're seeing an rpm change while driving at highway speed, switch on the gear indicator to verify the transmission isn't hunting between two or more gears. If it's staying in 8th gear, but you see engine speed increase by 200 rpm periodically, the torque converter is unlocking. That can be due to a brake light switch that's out-of-adjustment and vibrating over bumps in the road. Hold the brake pedal up with your foot. If the switch is causing the problem, the engine speed will hold steady while you're holding the brake pedal.
It's much less common, but a throttle position sensor, or more likely a corroded connector terminal for it can cause the torque converter to unlock too. Normal range of sensor signal voltage is 0.5 to 4.5 volts. Anything outside that range is what sets diagnostic fault codes. If you approach one of those maximum values, the Engine Computer interprets that as "wide-open-throttle", or "closed throttle" and preparing to come to a stop. Either condition initiates a momentary torque converter unlock. I haven't looked yet to see if my truck uses the same old-style throttle position sensor or if it only uses the one built into the throttle body assembly.
You can also watch engine speed on a scanner while on a test drive. The scanner will also show the torque converter clutch as "locked", or "on", or "unlocked", or "off". If you see it switch to "unlocked" when rpm increases, you still have to look at the other sensors to see why the computer is unlocking it. The "record" function that most scanners have is useful for this. You can play the short recording of sensor data back slowly in the shop to see what changed when the torque converter unlocked.
Aug 8, 2019 at 4:22 PM
