RPM drop very fast on gear change, when push clutch
2012 RENAULT LOGAN
31,000 MILES • 1.5L • 4 CYL • FWD • MANUAL
DAWINCHI
i have the car listed above (it is called l90 in Iran and made here). when i want to change to higher gear and push the clutch the rpm's drop too fast and when i push gas, the car does not go smoothly and have shakes. what is the problem then?
another thing is when car is standing, if i push gas,when gas return i have shakes and its like the car is going to turn off!
and no error is in dash.
(sorry for bad English)
Sep 11, 2017 at 8:03 PM
No problem. It sounds like you have one of two problems; first I would check the throttle bore of coking which is a dark goo over it which will make it not work right.
Here is a guide to help you see what I am taking about:
Next would be a vacuum leak which will cause the engine to hunt for idle which will make it drop rapidly.
Please let us know what you find.
Sep 12, 2017 at 12:57 PM
DAWINCHI
i will check throttle.
Thanks a lot.
i changed washer of manifold and throttle for the vacuum, but noting changed.
Sep 12, 2017 at 1:05 PM
It kind of sounds like the engine is misfiring, have you done a tune up lately?
Here is a guide to help you get the job done.
https://www.2carpros.com/articles/how-to-tune-up-a-car-engine
If the plugs are new lets run the codes to see what come up.
Sep 13, 2017 at 10:30 AM
