RPM are too high at an idle 1,000
2002 TOYOTA SIENNA
165,000 MILES • 3.0L • 6 CYL • 2WD • AUTOMATIC
TOMMY KORAKIS
In April 2018, I changed the Idle Control Valve. Everything was working fine. The other day while I was seated in the vehicle with engine running, suddenly the RPM went to 1,800-2,000 at an idle.
The check engine light gave a code of P0440 EGR valve. I replaced the valve with the same results high RPM.
I replaced the Idle Control Valve and the RPM sit at 1000-900. However the RPM do fluctuate. While I am driving the vehicle the RPM increase abruptly. You could hear at an idle the RPM increase and decrease.
Nov 5, 2018 at 2:49 AM
Good morning.
Did you clean the throttle body plate of all carbon? Build up of carbon will not allow the plate to close giving you a high idle.
Nov 5, 2018 at 4:38 AM
TOMMY KORAKIS
Thanks Roy.
Nov 5, 2018 at 1:02 PM
You are welcome.
Always glad to help.
Nov 5, 2018 at 1:46 PM
