As far as the CKP, there is no relearn on this vehicle. Have you found an issue with it? By the way, here are the directions. See pic 1 for location.
1996 Ford Aspire L4-81 1.3L SOHC
Procedures
Vehicle Powertrain Management Sensors and Switches - Powertrain Management Sensors and Switches - Computers and Control Systems Crankshaft Position Sensor Service and Repair Procedures
PROCEDURES
1. Disconnect the battery ground cable.
2. Disconnect the electrical connector from the Crankshaft Position (CKP) sensor.
3. Raise and support the vehicle.
4. Remove the right hand front splash shield.
5. Remove the retaining bolt and the CKP sensor. If necessary, remove the CKP sensor bracket.
6. Reverse the removal procedure to install. Tighten the CKP sensor to 6 Nm (51 lb in). Tighten the CKP sensor bracket to 3 Nm (15 lb in).
_____________________________
As far as the fuel pump, the pressure is still within spec, so I question of that will make a difference.
Dec 22, 2020 at 8:26 PM
