Tachometer stopped working while driving
2013 HYUNDAI VELOSTER
122,000 MILES • 4WD • MANUAL
JABSEB1956
While I was driving the tachometer stopped working went all the way to zero my car kept driving. I was still able to shift. when I got to where I was going I turn my car off tried to turn it back on and it would not start. I let it sit for about fifteen minutes and it cranked right back up with the tachometer working again.
Apr 10, 2019 at 11:14 AM
Hi Jabseb1956
Unfortunately there are a lot of things that could have caused this. The fact that it was only the tachometer that went to zero tells me there could be an issue with the input shaft speed sensor because that is what tells the Transmission control module what the RPM of the engine is and obviously the tachometer is displaying this input.
However, when you add the fact that the vehicle would not start to this, the input sensor would not prevent the vehicle from starting. This part of it is what makes this more complicated.
Due to there not being one or even a few items that could cause this, I would suggest getting the vehicle scan for any diagnostic trouble codes and let me know what they are. If the tach went to zero and then would not start, I am sure there are some stored DTCs in the computer and those will tell the story about what happened.
If you don't have the ability to pull these out yourself, you can go to most parts stores as they offer free services just to get the DTCs. They may recommend what they think but if you want to run those by me first, just reply to this post with what you find and I will be happy to dig further.
Thanks
Kenny
Apr 11, 2019 at 5:51 PM
DOUG16
Hi. I was wondering if you figured out what the problem was. I am having the same problem with my 2013 Chevrolet Sonic. Please let me know. Have a great day
Jun 5, 2020 at 6:20 AM
I am hoping we will get a response with what solved their issue however, even if we do your vehicle is not very similar to their vehicle so I am not sure their solution will solve your issue.
More then likely you have a vehicle speed sensor issue but let's start with the basics. What engine do you have and when your speedometer stops working, does it start again on its own or when you turn the vehicle off and then back on?
Jun 5, 2020 at 7:48 PM
DAWGRIT
I have the EXACT same problem with my 2012 Veloster 1.6 L 4-cylinder. Error code P0335. Faulty crankshaft position sensor “A” circuit.Di you have any follow up? Is this an easy fix?
Mar 28, 2021 at 8:06 AM
Unfortunately we do not have a response. However, if you have that code it is normally one of 3 things. Either the sensor (most likely) the wiring, or the control module.
Unfortunately again, we don't have a module on your vehicle so we can't provide specifics but here is a guide on how to replace a crank sensor:
Hopefully this helps but this is where I would start.
Mar 29, 2021 at 6:57 PM
