1995 Rover 2 Series Help
1995 ROVER 2 SERIES
104,000 MILES • 4 CYL • FWD • MANUAL
GRAHAM86
My Rover 220 Gsi needed a new Battery. So ive replaced the Battery and now the car alarm needs resetting. This is the usual case and ive used the code to reset it a number of times with locking and unlocking the car in a sequence. This time it hasnt worked and the red car alarm light stays on!! Now what do I do with an immobiliser that I cant turn of? When I connected the Battery there was smoke coming of the positive terminal. I didnt use the correct order in taking the leads of. I put the earth on frst and them the positive. Im worried ive donr something major. What dya think?
Apr 26, 2009 at 9:20 AM
DAVE H
  • 13,384 POSTS
disconnect the battery agian for at least 5 minutes ...Check the battery for a good charge and check all main fuses are not blown ... then reconnect the battery in the correct sequence if it is still good ... then retry the 4 digit code on the drivers door ... it should work this time !! hope this helps, let me know
https://www.2carpros.com/forum/automotive_pictures/266999_AAA2_596.png
Apr 28, 2009 at 7:36 AM
