When you coast up to a stop, and just before it stops it will jump forward like it just jumps into 1st gear. Had it to GM and they replaced the fluid and some wiring harness in or on the transmission. It seemed to do good for a while but after a month it was back doing the same thing. Took it back and dealer said it was doing okay, contacted GM and really no luck there. Even the service manager said that GM had no fix for this problem. It has jerked so much that there seems to be some backlash in the rear end as there is a clunk when going from forward to reverse, GM has a white paper on that as well.
This problem is all over the internet, just search for "problems in 2016 GM transmission".
Had someone contact me and said they had the valve body replaced and that corrected his, on his dime of course.
Any help will be appreciated.
Jim.
Jim.
May 18, 2024 at 7:11 AM
