The compression sounds excellent, so we know it has a healthy engine.
It could be a fuel injector issue. However, I still feel it would have set a code.
What you could do is a fuel pressure test and then see if the pressure drops off fast. If it does, that could indicate a leaking injector. Here is a link that shows in general how to test fuel pressure:
Your vehicle, because of the model year, will require a T fitting between the injectors and the supply. At that T is where the gauge is placed.
I do have another question. Are there any odd sounds from the exhaust that may indicate a possible partially plugged catalytic converter?
Take a look through this link. You may find it of interest.
https://www.2carpros.com/articles/bad-catalytic-converter-symptoms
Let me know. Also, let me know if this has the 22R or 22RE engine. I'm assuming it's the 22RE. Additionally, let me know if you smell fuel, see smoke from the exhaust, or anything you feel may help me. If you could record it running and upload it for me to hear, it may be helpful.
I attached the fuel pressure specifications below for the 22RE engine. If you have the 22R, it will have a mechanical fuel pump and the pressure is much lower, so let me know.
See pic below.
Apr 17, 2022 at 8:02 PM
