Rough running
1990 FORD F-450
120,000 MILES • 1.5L • V8 • 2WD • AUTOMATIC
SAMEASEVER
  • 25 POSTS
How can you test a fuel injector for spray without taking it out? I have good compression and fire at the number one cylinder but a miss.
Sep 17, 2018 at 1:44 PM
DANNY L
  • 5,648 POSTS
Hello, I am Danny.
Unfortunately, that cannot be done. What you can do is go to your local auto parts store and see if you can rent a noid light set. You install that into the fuel Injector harness and it will light and pulse if the injector is receiving a signal. If that is the case and you are getting a signal then it is possible the Injector is faulty/leaking/clogged/defective. Hope this helps and feel free to ask any questions. Thanks for using 2CarPros.
Danny-
Sep 17, 2018 at 3:14 PM
SAMEASEVER
  • 25 POSTS
Thanks!
Sep 18, 2018 at 8:49 AM
DANNY L
  • 5,648 POSTS
You are welcome!
Thanks again for using 2CarPros.
Danny-
Sep 18, 2018 at 12:12 PM
