Rough running it barely goes?
2002 NISSAN XTERRA
200,000 MILES • 3.3L • 6 CYL • 2WD • AUTOMATIC
SHAUNMU
It starts fine idles but when throttle engaged it barely goes, firing order is correct.
Dec 24, 2024 at 2:25 PM
Do you have a check engine light on, if so, we need to run the codes to see which ones are stored, this guide can help:
This can be a clogged catalytic converter or a bad TPS. We need more information to help you.
Dec 26, 2024 at 12:26 PM
