When changing gears from park to reverse the car vibrates. In neutral in smooths out and in drive in vibrates once again. MAF sensor went bad and was replaced once the check engine light came on. Changed the PCV valve that was failing causing the MAF sensors to be damaged. Changed the original spark plugs and coils (original plugs were not gapped properly to 0.044). The car smoothed out and the vibration stopped. The 2nd time the MAF sensor was changed the car once again started having vibration issues once again at idle. The only codes present beforehand were P0171 and haven’t come on since changing the MAF sensor. No codes now but car is having rough idling.
Feb 23, 2025 at 9:59 AM
