Rough idle and stall when cold
1991 NISSAN 300ZX
56,605 MILES • 3.0L • 6 CYL • 2WD • MANUAL
WOLF10EV
My car starts fine but will not idle unless I keep my foot on the throttle until it warms up a good bit. It sounds great and no miss at all when revved up but does have somewhat of a miss when warm and idling. I have made various setting changes at the TPS and it does seem to have some effect. I have done this with two different TPS sensors. Do I have an injector problem even if it sounds great when revved and could it be something else?
Mar 24, 2022 at 10:08 AM
Normally a rough idle when cold is due to an air fuel imbalance. So that means we have a fuel pressure issue that gets better when the engine warms up.
So let's start with checking the fuel pressure just to be sure it is not the issue. Here is a guide that will show how to do this:
If this checks out then we will need to check for a vacuum leak.
Basically if you have unmetered air coming in then the PCM doesn't know to adjust for it. However, once it is warmed up and it starts looking at o2 sensor data, it is able to compensate for it and the idle smooths out.
Once we run through these two issues we will have a better idea where to go.
Thanks
Mar 24, 2022 at 4:47 PM
WOLF10EV
Thank you so much.
Mar 24, 2022 at 6:17 PM
You are welcome. Please let us know how this turns out. We are curious to see what the solution is.
Thanks
Mar 26, 2022 at 9:27 AM
WOLF10EV
I'm leaning towards it being a faulty TPS. In shopping for new one's I wonder why there's a difference in them do NA cars vs Turbo cars. How much different could they possibly be?
Mar 26, 2022 at 2:51 PM
They operate the same but the voltage readings they give are slightly different for the module to respond to. You will want to stick to the correct one for your engine.
Let us know how it turns out as that info will surely help others.
Mar 27, 2022 at 7:15 PM
